No cranking. P0340 code
bspurloc
295
Ok I did google and search here but 1> I don't see complete relation and 2> Roadie confused me with a link on that "other" site which I see a $34 part and then a $90 part. ok enough with I'm sorry I made another post about this mumbo....
Ok.. My daughter told me today her car is not starting. she turns the key past accessory but it does not crank. she tries it again and vroom. she says this happened twice today and maybe twice in the last month or more... hard to pin actual valid info from her...
She said the check engine light was on today and then went off. (I dont know how long or if it was between off on cycles)
I checked the codes and saw a P0340. I changed her oil and reset it last week and change it when it gets below 5%.
camshaft position sensor circuit malfunction. I did not look to see if it was leaking ASSUMING this is the part behind the power steering pump. We replaced a clogged Cat around 6months ago. It has been running nice since that replacement.
Cruise control is working she says...
dfc739
170
Des Moines, IA
P0340 is common enough MAY03LT made a really good video about troubleshooting it. [video=youtube;1ZRpcAAbNVw]http://www.youtube.com/watch?v=1ZRpcAAbNVw[/video]
Don't confuse the camshaft position sensor with the camshaft position actuator solenoid (CPAS). One is just a sensor that detects a spot on the camshaft and the other is an oil pressure activated solenoid that changes valve timing. The cam position sensor is on the front of the head and the CPAS is behind the power steering pump.
It also sounds like you have another common problem: the ignition switch. It's problematic to the point that some people on here carry an extra in the glove box. Swap it out. For instructions just search "trailblazer replace ignition switch". Edit: http://dl.dropboxusercontent.com/u/11447531/ignition switch replacement.pdf
bspurloc
295
Well that video was a bit odd not sure I learned anything however this video he mentions if this switch is acting up u will get the trouble starting the engine
[video=youtube;_dIjD0KM8AM]http://www.youtube.com/watch?v=_dIjD0KM8AM[/video]
"If your having trouble starting your SUV when you turn the switch then replace it."
Guess I will just replace this. She says the check engine light was on half the day but its ok now.
so advance auto pick up blah
ACDelco Camshaft Position Sensor
thanks
bspurloc
295
The electrical part of the ignition switch is not the same as the key cylinder. The switch guts are MUCH cheaper.
bspurloc
295
Cool thanks
Bbcman601
