First off thank you to anyone that can give me any advice. It is much appreciated.
My wife was dropping my child off at school this morning when her Trailblazer died in the middle of the street.
With the help of a crossing guard they pushed it out of the way.
I was not able to get it started and had it towed to our home.
First thing I did was run a fuel pressure check...none.
I followed a test procedure that i found on you tube that involved removing the fuel pump relay and probing the socket.
standing over the driver side fender, facing the fuse block i get the following:
Lower right hole has battery voltage.
Lower left hole has good ground.
Jumping lower right to upper left gets me around 42 psi of fuel pressure. (seeming to rule out the fuel pump?)
Here's the kickier. Upper right has nothing. No voltage key on or off.
Any ideas?
Thank you very much for any help.
Any ideas?
