I had to recently replace my PCM because i had a ground hog climb in my engine bay and chewed my AC wiring and it fried my old PCM so i had to order a new one from PCM of NC. Everything fixed once i put the new PCM in but now when i drove it for the first time today to work and home I noticed that it wasn't shifting into OD.
it would go through all the gears but in 4th it wouldn't go up to OD the RPMs just stayed high in the 2k when i was going 60. I never had this issue prior to then the car ran fine transmission gave me zero issues. The shift points have been higher since i put this new PCM in i have noticed.
Only check engine light code was for EVAP, its a 03 trailblazer ls with 4.2l I6, motor and trans has around 162k miles and transmission doesnt slip shifts good.
Any recommendations on things to check?
