New and improved washer nozzles
Grimor
954
My washers stopped working soon after I got the truck, and it seems to be a somewhat common issue. So I swapped in some ford/mazda "fluidic" nozzles Part number EC01-67-50YA
They are a little smaller so I just JB welded them in and made sure I had them pointed where I wanted.
[video=youtube;iuaBL7pLJqA]http://www.youtube.com/watch?v=iuaBL7pLJqA[/video]
[video=youtube;N_4HIlpNmDo]http://www.youtube.com/watch?v=N_4HIlpNmDo[/video]
Sitting still, they tend to put a bit of water over the windshield...
Moving down the road they are about perfect.
The only thing I want to do is replace the line, it has a couple kinks in it and I want to route it so the T is on the driver side (you can see the lower pressure in the video), a bit better pressure. For ~$20 I recommend it. I will get a couple pictures of the nozzles installed tomorrow probably
Grimor
954
ok, at what point do you give up and just go a little overboard....
Pulled the fluid tank and flushed it, went with larger hose (7/32)
I tried an inline filter but it built up enough pressure to pop the lines so I took it out.
[video=youtube;vvoTHrMSEtI]https://www.youtube.com/watch?v=vvoTHrMSEtI[/video]
my loaner phone takes crappy video, and it is hard to see the mist, but it just pumps the water out.
works better when moving, but even sitting still it works great.
dmanns67
32,979
Wow. So basically your winshield washer doubles as a sunroof washer as well :wootwoot: . You give that thing any more power and you can disconnect your rear window washer and have a three in one :raspberry:
Grimor
954
Is 60gph too much?
dmanns67
32,979
Grimor said:
Is 60gph too much?
Of course not. Just keep some spare jugs of water in the TB and you will be fine. I am sure the driver's on the interstate driving behind you will love it when you clean your windshield lol.
Grimor
954
At least now I don't need a fire extinguisher in the garage, as long as I'm parked on the same block i can put it out
dmanns67
32,979
True story. Yours are quite the opposite of mine. Every 6 months seems like my driver's side washer nozzle/line gets clogged and stops working. I might have to upgrade my lines as well.
Grimor
954
Have you pulled the reservoir and washed the tank? I had some grit/floaties in mine that was clogging the nozzles. I also had kinks in the old lines
dmanns67
32,979
No, but that is a good idea. I usually just blow out the lines with air.
Grimor
954
Grey Thunder said:
How hard is it to pull the fluid tank? I need to pull mine out because I have a nice leak in it! lol
Not hard once the air box is out of the way
May 20, 2013
29
how did u gain access to the nozzles and the lines?
did u disconnect the wiper arms and remove the bolts that hold down the panel where the wiper arms and the nozzles sit on?
Grimor
954
yup, that's pretty much it
kraymates
