Thanks for the reply IllogicTC, however I need the mounts for the V8 5.3L; gmpartsdirect does not show any for the 5.3, and old discussions on the boards indicate they aren't available.
Thanks for the welcome Wooluf1952, and you are correct, My XUV is a 2004, I've owned it since 10/2004 (I corrected original post). With the help of this site and the old site, I've changed rear air bags and A/C mode actuator. Stock vehicle with only a few issues like rear and mid-gate window regulators. Currently needs motor mounts, lower control arm bushings, and the typical stepper motor / light replacement on the guages.
Back to the motor mounts: GMparts direct and RockAuto have NO mounts listed for 2003 or 2004 Envoy with 5.3L V8. RockAuto has aftermarket (DEA) for 2005-2009 Envoy 5.3 for about $60 for the pair, does anyone know if these will work, or the quality? GMpartsdirect also has mounts available for the Envoy 5.3L V8 in the 2005+ model years for about $327 for the pair. Once again, will these fit? Are they better quality than the non-OEM from RockAuto?
Can anyone that's replaced these on a V8 4X4 comment on how difficult it is? Has anyone outlined the procedure? Thanks for the welcome, the replies, and help.
