Mirror blinker fuse?
Kuchar09
I'm installing my new mirrors and was trying to test for a blinker wire. I believe blinker is white wire and green wire considering those are the only ones not wired up from the ones I thought i needed.
But anyways I had voltage accidentally touched something and had a spark and no no more voltage.
I swear I have checked every fuse under the hood and seat.
Front and rear blinkers still work and passenger mirror still works also.
Is this just a fuse that I am missing (wouldn't be the first time :crazy:) or is it something more?
Did you lose any other functions in the DDM? I know when I was doing some mirror tinkering and current went somewhere it shouldn't, that particular function stopped working until I unplugged it from the DDM, and plugged it back in. I have no technical research to back this up though, could be completely coincidental. :redface:
Edit: Green is the blinker, white is the ground BTW
Thanks... for whatever reason I plugged in the wire and now they work. Couldn't get voltage but whatever they work. Thanks for the quick reply tho!!!
lsx.trent
