I have done rust repair before.
There is rust in what seems to be the most common areas, on the front lip underside of the hood
And door seams at the bottom (lift gate is clean as can be currently, thankfully)
Since the truck (04) only has 94,000 miles. I want to repair this rust. Grinding it down, and painting it is not a problem at all. I did that many many times over on the previous 93 Jimmy. But it obviously kept coming back.
I was reading many posts about treating the area after with rust preventor. And also coating the bottom inside the doors to prevent moisture that gets into the doors from getting to it.
What would be a good product to use on the inside of the doors, and also a good product to use once I have wire brushed/ ground the rust away?
I have seen some sites say Chassis saver for the inside of the doors.
Thanks!
Thanks!
