Steveinfl
- Joined
- Dec 6, 2011
- Posts
- 62
Hello Everyone,
Turns out the storm brought nothing but weak thunderstorms to Central Florida. I ended up searching around on amazon and pricing out replacement parts.
-The vehicle is a 2003 LT 4.2. Only modifications currently are cosmetic the hollowing out of the air box. 82K miles
I am driving to visit a friend in Boston towards the end of the year and figured its just time to catch up, and do some preventative as well. Past maintenance has been good, here is a summary:
Date Odometer Provider Work Warranty
8/11/2005 22,232 Holler Chev Brake fluid flush
Injection Clean
2/12/2007 34,419 Mobil Lube Power Steering Flush
Belts: Poly Rib Belt
7/12/2007 37,083 Holler Chev Fan Cluth replaced
4/18/2008 41,833 Mobil Lube Air Filter
6/9/2008 42,641 Firestone 4 New Tires
Tire Rotation Lifetime Rotation & Alignment Service
5/27/2010 59,485 Firestone replaced CAM position senson
replaced thermostat
Did TWICE (see below) replaced upper/lower radiator hoses
Coolant Flush W/Sealer - Antifreeze Good for 50,000 miles
6/25/2010 60,416 Firestone AC - blower motor resistor
fluids change at 60,000
10/28/2011 72,600 OIL CHANGE, fuel filter, cleaned throttlebody, spark plugs, techron, tire rotation
4/26/2012 78,200 OIL CHANGE, fuel filter, techron, tire rotation, new brake pads and rotors, FLUSHED brake fluid, changed differential fluid
NOTES: I took ownership of the vehicle in 2011, immediately performed the services shown starting 10/28/2011. The rear diff oil was disgusting and changed when I noticed it intermittently locking up. The coolant was the wrong color and I am still running several (no more than 214) degrees above normal when in stop and go. I modified the weather stripping significantly and cut the noise down some, it is still a loud vehicle above 75 on the highway. I need to commandeer an assistant and complete the brake flush, very little luck with the one person vacuum kits. I will try a bleeder bottle next. I feel but have not verified that I have a weak fuel pump, it is the OEM unit. It is either a weak pump, broken check valve or potentially malfunctioning FPR. I am unsure how to test the pressure past the main line schrader valve, as in past the FPR. Vehicle otherwise runs very well, I am nit picky and notice every little thing which is off. I realize that there are certainly other things which need to be changed. These include all suspension components, bushings, motor mounts, trans pad, still on OEM wheel bearings, more than I care to think about or list.
The following list is what I have tentatively planned for the next several weeks. If there are any other jobs I should do while I have things apart please let me know. I tried to consider as much of it as I could already.
Cooling Related
Fuel
Other Miscellaneous
I am not necessarily looking for a how to on these items, just if there is anything else that I should consider. The vehicle used to take many short drives, I drive farther usually than the previous owner but it is still a city vehicle. My mileage has declined steadily, I average ~11 in the city ( not awful considering my right foot) and 17 on the highway ( at reasonable speeds). Techron treatments with each oil change have not improved this. The average driver would not even notice these little things, they are minor. I just can't help but notice the gremlins, as is the case for most of you.
Thanks and War Eagle
Injection Clean
replaced thermostat
Cooling Related
- Fan Clutch 15-40133 ( or EFAN, open to suggestions)
- 4069015 Gatorback serpentine belt
- bosch 96166 water pump (competitive to the delco unit in price)
- stant 14695 thermostat
- 213963 Coolant temperature sensor
- 12573024 Drive belt tensioner assembly
- Idler Pulley 15-20679
Fuel
- MU1837 Fuel pump module Delco
- 217-1445 Fuel pressure regulator
- gt276 Fuel Cap (current one doesn't always pass pressure test)
- 213-1551 front oxygen sensor ( so many part numbers for this, is this the right one?)
Other Miscellaneous
- Fuel, oil and trans filter change
- 5 Gallons of trans fluid so I can change the fluid myself according to our writeup. ( I am going to attempt to use a drill operated pump for fresh fluid while it pumps out)
- Spark Plugs just because
- Air temp sensor for intake
- Map Sensor? (does this wear out)
- CPAS- I am unable to find a part number here. I think amazon just doesn't carry the OEM part, just dorman which I will not use.
- Go to a junkyard and buy a handful of ignition coils for spares and replacements. Is there a good way to bench test them with a 12v power supply?
I feel like I don't even need to post because you just reiterate after everyone else.
