I have been reading through threads all day trying to find one that matched my symptoms AND had helpful replies. So, here is my issue...
2006 GMC Envoy Denali XL, 5.3L V8, 4WD, Automatic
Driving home last night the oil pressure dropped to zero and gave me the low oil pressure message. Pulled over, shut off the motor, restarted it and got oil pressure back, turned around and headed to the closest gas station to put oil in the motor (assumed it was low). I now know I have over filled it with about a quart of oil, but that is better than no oil. Got oil pressure back and was able to drive the rest of the way home with no issues. This morning, light came back on about 2-3 miles down the road, same issue, turn it off and back on and get some pressure back on the gauge for a short distance. So tonight after the vehicle has cooled down all day, I restart the motor to watch and listen for symptoms.
Great oil pressure when the motor is cold, right around 40-42. Once the motor gets to operating temp the pressure drops and trips the light. Turn off and turn back on, the oil pressure comes up to 15-18 and then slowly drops down again. Repeat process and the gauge always resets to 15-18 and then slowly drops again.
What I can determine from what I have read is that it is most likely a faulty oil pressure sensor for the gauge. The motor sounds normal so its not likely to be a faulty oil pump, and the gauge is consistent so its not likely to be a faulty gauge.
Thoughts, solutions, had this problem happen to you before and figured it out?
