The Tech 2 just flashes "loss of communication" and beeps repeatedly when I try to get it to read codes.
Also, it will request info from the ECU for the SPS just fine but after I load the updates from the PC and hook it up to the obd port, it cycles through everything and then says failure. It seems like it sort of communicates, for instance one of the updates was to calibrate the fog lights.. it switched the lights on at one point and I could hear other clicks and noises from under the hood but ultimately, it fails.
I tried to do a crank relearn and it let me get all the way to the final step before it started the flashing beeps of failure. Sometimes it will say I may have entered the wrong vehicle after failing to do something but I know for sure the info is correct.
