Alright guys I got another issues. We pulled the hids out and put regular bulbs in it about three weeks ago. Since then out left blinker arrow on the cluster is slightly lit, the left headlight doesn't light up completely, both high beam bulbs glow when the low beams are on, and finally we have replaced the left turn signal twice. It will work normally then go out and start blinking through the low beam bulb? Also if we use the high beams while driving or sittin the truck will stall, and only the right low beam and high beam will light up the left goes completely out? I'm about done with it... Any help would be greatly appreciated.
