Well everything is wired and running, tell you the hardest part of getting the upper dash piece back in place was seating the clip in the middle between the rest of the dash and the light sensor, little tip for any newb out there, pull the A-pillars before re-installing, much easier then fighting around them. I busted the cardboard a bit on the first one (see picture). also I need to do some additional sound deadening on the rear doors so I can re-install the rear door panels without getting a lot of vibrations, now that those 8's are getting way more power then before.
