Hi again.
After my last post back in February, I no longer had issues with my brother's 2005 4.2L I6 Trailblazer. It didn't last long.
About three weeks ago, it started really acting up. It would just crank and crank, but not turn over. That was unless you floored the gas pedal, then it would reluctantly start up, but run like garbage, spluttering and not running smoothly. On the second try, it would almost do the same thing but keeping the pedal to the floor, the engine would rev up, whereas it wouldn't do that on the first try. This was an issue every other start up. There would also be a decent amount of smoke pouring out of the exhaust and a fairly strong gas smell. (I hope that makes sense)
It hit a high just this past Monday when I went to start it up. I followed the same procedure of starting it twice with the gas pedal pressed to the floor. It started and ran ok. It was idling around 1500 RPMs which is a little high for this trailblazer. When I put it into drive, it almost shot off versus just slowly moving when the gas pedal isn't pressed. The trailblazer started accelerating high enough that it was shifting into 2nd gear without the gas pedal being pressed. When I shifted into neutral, it would rev up to almost 3000 RPMs. It would stop when I pressed the brake pedal in all the way, but I could feel it fighting against it. It only did this for about 2 or so minutes before it went back to normal. Since then, the trailblazer has started up first try with no issues.
Along side all this, the coolant gauge stopped working and the "check gauge" light came on. Coolant was still making its way through the engine thankfully. It was however reading that the coolant was -40 degrees F. I replaced the coolant temp gauge with an Echlin one from Napa. It worked once on the first start up, but stopped reading on every start up afterwards. I haven't checked any electrical connections or for voltage anywhere.
I can still occasionally smell gas or exhaust when I'm driving with windows down.
Any help would be appreciated. Thanks.
