Is it true...
Voymom
2,523
Is it true that the brake lines and fluid need to be flushed every year or two? And is it supposed to smell like acetone and be green?
This is probably the only fluid I don't know much about. We haven't added anything to it, and what's in it now is what was in it when we bought it. I'm just looking for clarification on the brake lines needing to be flushed every year or so, as I have been told.
Thanks!
ksimm92
166
defiantly should not be green, the fluid should be as close to clear as possible, and not smell like anything really. I change the fluid when I replace the pads. I use a turkey baster and suck all the old fluid out of the reservoir, then add new fluid and bleed all the lines until it comes out clear (and add new fluid as I go along).
It's important not to let the reservoir get empty.
There are also brake fluid test strips (google it) to check the fluid. They test for copper in the fluid.
northcreek
3,331
WNY
Thanks!
You could also replace the fluid with dot5(silicone) brake fluid.It's expensive but, you would only have to do it once.This is what the military and classic car guys use,as well as motorcycles...Mike.
NJTB
612
Flemington, NJ
Yes, it's true brake fluid needs to be changed, but not every 1 to 2 years. About every 3 to 4 is good as long as the car isn't driven in major dust, etc.. As another poster said, there are test strips available to check the condition of the fluid. I change mine if it looks too dirty.
Be careful with silicone brake fluid. It don't mix with DOT 3 or 4, which is what the TB calls for. It's written on a label on the filler cap.
northcreek
3,331
WNY
And I did say replace not add silicone brake fluid.Silicone fluid is for the most part inert so it won't attack seals and metals.I have used it with great results over the years,the problems arise when people put dot 3or4 in an originally designed slicone system, then the gremlins get to work....just sayin',Mike.
I've always been told not to use silicone brake fluid in ABS systems.
Something about foaming when the ABS kicks in. Just recently, again, on the Goss's Garage segment of Motor Week.
northcreek
3,331
WNY
You are right,I wasn't thinking ABS:redface: Actually DOT 5.1 is for ABS but,it's not silicone and just another variation of Dot 3&4,not really any advantages to it...sorry if I misled anyone...Mike.
meerschm
1,079
Motive Products #1 Selling DIY Brake Bleeder
These guys make it a lot easier to flush the brake fluid. they sell versions for one master cap size, or one with a fitting to change in and out from several, (in my case, a Chevy and a VW).
you can do it without, but almost need three people, one to make sure the master does not run out of fluid, one to open and close the bleeder valve, and one to press the brake pedal in coordination with the bleeder screw turner.
with a bleeder and bottle, you can set it up, (check for leaks, which i was a little lax on last time I did it) and proceed around, bleeding out the old bad, while the new flows into the system.
or you can pay someone for the service.
my VW specs to change brake fluid every two years. not a bad idea to do this on any car or truck with over 5 or 6 years on it.
there is a video someplace.
onlyatauction
