- Jul 26, 2015
- 30
I recently picked up at intake manifold from a friend off a Trailblazer (not sure what year) for $20!!!
Seeing as my intake has practically been melting from the long years of heat I said what the heck? Might as well change the intake if I'm going to replace the valve cover as well because it's leaking like crazy and broken where I can't properly secure the resonator anymore, plus I think I have a pretty good sized hole on one corner of it.
So the question is the MAP sensor, this intake that I picked up looks exactly identical to the one I have on my 02 trailblazer EXCEPT the MAP sensor seems to be held on by a bolt now. Since when did they change the MAP sensor on these trucks? My uncle has an 06 TB and his intake is the same as my 02!!!
I found a MAP sensor that's for a later model TB that looks like it can fit this intake. Can I just swap them? The connector is the same 3 pin. Or should I ditch this intake and sell it?
I attached a picture of the new intake, does it look like any of yours?
