I have done it!!! Convinced my Mother that her wanting music in the truck, and a Bose system that does not work under 65 degrees is a dumb idea. (plus she likes the idea of streaming pandora)
Since She bought the truck in January of 2009 the stereo has only worked above 65ish degrees, I have gone through all of the connectors cleaned and reset them, found out the relay inside the amp is not the problem. This is the first vehicle she has owned with a "premium stereo" (Her and my Father seem to think Bose is the best there is) and she was hesitant to let me replace it because "Nothing will sound as good"... I finally got through to her that the stereo does not sound to good when it does not work...
She wanted to do this on the cheap so for now we are keeping the factory speakers.
Since the speakers have a 2ohm impedance, I was a little worried about over-driving a new head unit (and the fact head units only power 4 channels). I told her the only safe way we could power the speakers was with an external amp.
My Mother took it upon herself to look for a head unit (she ran them by me just to make sure it did what she wanted) we decided on the JVC K900BT, it is a double-din with bluetooth, 2 USB inputs, front 3.5mm AUX 3 sets of RCA out, and time alignment. All for $150
I knew I had to find an amp that would power all 6 speakers but it could not cost much, so I decided on the PPI Sedona 580.5.
I am going to wire it up in this fashion, through the output harness that was plugged into the Bose amp.
Front Channel = Dash Speakers
Rear Channel = Rear Doors
Sub Channel = Front Doors (wired into the same channel)
I know it will take some tuning of the crossovers and T/A to get it sounding decent.
I know this install is nothing special, but I will be taking photos during the install just to document it.
We have all of the big stuff (Head Unit, Amp, and Chime interface/harness) Just waiting for all the little stuff like RCA cables and ring terminals to come in.
She is just under $300 dollars for everything, so not too bad.
