Let me start off by saying I broke down and ordered a few things, some I needed and others I could have done cheaper.
First off I ordered some LED tails, I know some of you guys are gonna say wtf is wrong with, but eh whatever I thought they looked good.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I also ordered some Revers LED bulbs and some Front turn signal amber ones.
I ordered some more 194 bulbs, I got 10 clear and I think they will be fine in the corner signals.
And finally I ordered the Brakemotive Drilled and slotted rotors and pads.
It was an ebay heavy day. Now for a few questions
Does any one have experience with these lights and needing resistors to counter act hyper blink? I have seen alot of confusing info about using 3 ohm 50 watt resistors at the tail, 6 ohm ones etc.
Next will be the Avalanche 3rd BL, and maybe some nerf bars who has a set they don't want any more?
If those tails you bought have built in load resistors, which I think they might, you may be able to simply swap your stock flasher module (just above and to the left of the brake pedal) with an LED flasher module LM487, which would be plug and play. Otherwise, you would need to go with the load resistors for the turn signals.
with what Carlton said...
