I need some help with AC compressor function
trailblazer075
323
LAGNY SUR MARNE FRANCE
The last week end i change my catalytic concerter and i disconect the battery.
And now my AC Compressor doesn t work With the serpentin belt.
The 10A AC fuse is ok.... CAN you help me please .
Wooluf1952
2,663
Milwaukee, Wisconsin
There are two AC fuses #30 and #44. Did you check both of them with a meter? Or just visually?
Wooluf1952
2,663
trailblazer075 said:
Just visual. I Check just some one 10A the 40#
44# is it a fuse?
Sorry, #44 is a relay. However my owners manual (2003 Envoy) lists #30 not #40 as the AC fuse. #40 on mine is the HORN relay.
Also, some times the crack in the fuse can't be seen. You need to check using a meter or test light to be sure.
Empty AC systems often require a specialist. Almost nobody has the tools to fix it themselves.
r1ryder
