i have a leak idk where its coming from
Valetman23
I have a leak that it appears comming from the heater core but its a clear liquid and doesnt smell like antifreeze. It seams to have even leaked into the compartment under the back hatch on the floor and rusted my tools i have cleaned out the ac drain by the hoses and it only leaks when a/c is on any help would be great i saw this post ounce on traivoy but never could get an answer. Thank You
Do you see condensate (water) on the ground near your passenger side door hinges? If not, then your drain really isn't cleared out.
Thank You Roadie I like all the info you put on the old site and the answer to your reply is no water leaks out like it should what should i use to clean it again? i used a Arrow that i broke down to stick in that drain and it was about 20 inches long. Would that also cause the leak to the back of the suv?
Sexyscissors
