How to remove TB/Envoy lower side trims and rear bumper step pad
Gerbil21
839
Time needed:
15 minutes per side
Tools needed:
Flathead screwdriver
10mm ratcheting wrench
1. Remove the two 10mm bolts on either side of the trims
2. Remove the 7 push pins on the bottom by putting the flat head in the opening and twisting side to side then angle the screwdriver to push down and it should pop right out.
3. Now remove the pin retainers by pulling down on the trim, they'll pop right off
4. Remove the last two push pins by the front and rear door
5. Now remove the front and rear trim by the doors by prying up with a screwdriver
6. Now remove the lower trim by pulling it down and out, but make shure both doors are open and make shure to get it around the rear door, you have to tilt it upwards and pull it down and out.
7. The install is just the reverse, the whole process is easy except for the trim getting stuck on the rear door
As for the rear bumper step pad
just pry a screwdriver under one side corner and it will come off pretty easy, then just pull it out
Reactions: jpimp and Mounce
SnowBlazer
5,775
Colorado Springs
Nice guide but I will warn anyone that this is done on an Envoy (06+ LT bumper) . Methods will be different for TB LS Models.
onlyatauction
