Presently... One of our Members is dealing with a P0325 Knock Sensor Issue that may turn out to be Bad Knock Sensor...BUT... What if it turns out that the Connector or the Wiring involved is the actual culprit? If there is either Rodent Damage from Gnawing... or if the Wiring inside of the Connector has corroded and decayed so bad the they separate, one from another..What can he DO?
Yes...the obvious choice would be to visit a Salvage Yard and try to grab an OEM section of the Wiring and Connector ASAP. But...there IS an alternative by visiting THIS Place known as Ballenger Motorsports (bmotorsports.com) and then browsing through their entire inventory and line up of Delphi Connectors, Plugs Harnesses... and LOTS more Items and use the OEM Images of each one to locate Brand New OEM Quality Replacements!
Ballenger Motorsports - High Performance Electronics
www.bmotorsports.com
