- Dec 4, 2011
- 242
Following the truckdigest how to as I am replacing my stock front shocks to bilstein hds. I am to the point where I am trying to use a tie rod wedge tool to remove the strut mounting arm from the lower control arm. Nut is off, but I can't for the life of me get this arm off the bolt/bushing. The strut arm moves when I pry on it, but the bolt moves out too - it looks like the bushing is pulling out too or something. There is a big metal head to the bolt on the backside, and it is about 1/4" away from the LCA and I can see the rubber through the gap, when I move the strut arm out the bolt head moves towards the LCA. My tie rod wedge isn't wide enough to fit over the bushing - it fits over the bolt just fine but not over the bushing, which is all that is visible between the strut arm and the LCA. Because of that, it can't go down far enough to actually drive the arm off. Unfortunately, thats the only wedge i have and the nearest store is 20 miles away and i would have to walk it.
So what do I do - tried pb blaster to no avail. Don't want to destroy the bushing cause I can't have the truck non-op long enough to get new bushings. Any advice would be greatly appreciated.
