Hood prop rod clip
fireman32_14
11
My 06 trailblazer is missing the little retainer clip that holds the hood prop rod in place when the hood is closed, does anyone know where I might find one of these or have a part number
Mark20
1,630
I had to replace that years ago on a F*rd. I got it at the dealer. You can try the Help parts at an auto store or online.
Redbeard
3,545
Hey richphotos,
I don't know if you'll get any answers from above with a date stamp of 2013, but two places I probably would check at is Rockauto.com and more likely a local junkyard. Dorman replacement parts also comes to mind at the local auto parts store. What vehicle do you have?
Someone else may pipe in also. It would be nice if those plastic parts held up better than they do.
Reactions: richphotos
richphotos
298
St. Louis Park, MN
Thanks. I knew I would not get a response from the op or anyone because the old date but I got my answer as intended.
I have an 04 tb lt btw. I should add it to my signature or something.
They should make plastic parts more durable or make something like this metal.
Thanks for the part number!
Reactions: azswiss
Yasha
