Hood latch lever spring
97blazer
Found the return spring (I'm assuming) laying on the floor under the lever. I haven't tore into it yet but I wondering if there are any tricks I should know. Specifically The lever dosen't seem to have any way of being retained. I can slip it in the pivot but it will slide right back off with no effort.
Thanks
I can't look at mine right now but the spring could be pulling the lever so it stays in.
I thought the same but it just doesn't look it. Which in my world means it probably does... To actually remove it it looks like I have to remove the kick panel. I'll be on it this weekend. LMK what you can see.
Thanks.
Broken hinge pin. I looks like the spring is what holds the lever in place by clipping into a slot in the pin. Won't know for sure untill I see an unbroken one.
Grab a quick shot but it was late and the light was going. The spring does go around the lever's hinge pin.
Thanks,I wonder why it broke? Oh well, I'll try pic and pull tomorrow trying to avoid the steelership.
Bones28449
