If you can find a console in the right color with the Homelink transmitter AND the options you currently have (sunroof, third row windows, etc.) then it's just plug-and-play to swap over the whole thing. They are out there--I found mine on ebay for ~$45 shipped.Blckshdw said:I did this mod a couple years ago. You don't have to replace the whole console, just the plate where the modules go. (bottom of my pic) Try to get some from a junk yard if you can, they'll be much cheaper that way. You need to pop out the light lenses, and there are a pair of T15 torx screws in the corners. Once you get those out, there are 2 clips near the front of the headliner, pull down. Disengage the wire harness, then you can work on the swap comfortably.
Edit: You'll also have to splice in some wires, for power, ground, and illumination (when the parking lights come on) Would be a good idea to download the wiring diagrams from Mooseman's Service Manuals thread.
LikeEnvoy said:My 07 Envoy has only the two map lights in the roof. Are the mounting points for the console already there in the roof? I.e. where the clips and screws go.
So apart from wiring, will the console just clip in and screw down?
Been there done that..AtlWrk said:The real trick is upgrading from a console with the sunglass holder ('04 and earlier?) instead of the map lights. It can definitely still be done, just requires some wiring and modifications to the mounting bracket.
