- Aug 27, 2013
- 76
08' TrailBlazer with 4.2ltr I6
On cold starts it will idle at 1000-1100 RPM and drop to 900 RPM in short order. After driving and coming up to operating temperature, when I come to a stop and the truck is at idle in gear it will be back to normal around 600 RPM. So now the warmer weather is here and it still acts like it's Winter time on start up. I'm wondering if there is a sensor that tells the engine / computer what the ambient temp is outside and how to moderate the EFI system? I imagine it's a wide range sensor so it maybe malfunctioning but still be in it's operating range, so there would be no trouble code just inaccurate temp readings. Anyone ever have such a problem?
Also, when I shut the truck down after a 30 minute ride home from work and restart it 15 minutes later it will high idle again like it was a cold start and drop again once again after idling or driving a bit.
Thanks for any help you guys can offer!
