Also when using the search bar here on the forum, it helps to click the box, "search titles only".
I was in the same boat you are now, 4 years ago and the aftermarket is still the same for TBLT headlights, nothing at all out there. If you want projectors, you will have to build them. The site Mounce posted, the retrofit source, is the preferred choice for quality projectors and HID kits. Use TRSHJ for 10% off your order.
The Morimoto Mini H1 6.0 or 7.0 is a really good "plug n play" projector as far as being able to install without cutting or modifying the headlight. I have a set of 6.0s installed in my wife's truck and they are great. The MMH1 7.0s are supposed to be even better.
You will definitely want a brand new set headlights for the retrofit. Plan to spend at least $300 for a new set of TBLT headlights. The Morimoto Mini H1 7.0 projector retro kit goes for $270 which includes H1 HIDs, ballasts, relay harness, projectors, shrouds, and hardware.
Here is a pic of my TBLT headlight with FX-R 3.0 bi-xenon projectors and E46-R shroud. I also run LEDs in my hi beams.
