I've been working at this for some time and so far haven't found a solution.
Here's what's going on.... I telecommute so have to use a work supplied router. The instructions they gave me say the following:
Modem --> internet port of work router --> port 1 of work router to work computer, port 3 of work router to personal equipment.
I have a cable from the internet port on personal router to port 3 of work router, internet port of work router to modem.
This works for most everything except for XBox Live. Having this particular set up causes NAT to be strict (since the work router cannot be configured by me in any way). In turn, this causes random disconnects on XBL... sometimes the connection will last 10 minutes, other times 30 seconds. There are other side effects to this setup, but the XBL one is the one I'd like to tackle at the moment.... the rest are gravy.
What I am wanting to do is this:
The home router is already set up for open NAT and whatnot and has all the necessary connections and port forwards intact to run everything on my home network w/out fail....
At my disposal as far as extra equipment I have a WRT54g running dd-wrt that is not being used (was for a time being used as a wireless repeater), an unused Linksys E1000 running dd-wrt, a netgear GS105 switch. The home router is a WRT310N on stock firmware, work router is an aruba something or other.
The home router is on ip range 192.xxx.xxx.xxx and subnet 255.255.255.0, work router is 10.xxx.xxx.xxx with an unknown subnet.... I can get the setup per the work provided instructions to feed through the netgear switch, but if I hook up the WRT54g (IP range 174.xxx.xxx.xxx) as a wireless router to the switch (just to test as to not mess anything up on the ghetto set up), no data passes through the switch, but data will continue to pass through the switch to the discombobulated setup....
I'm supposing I can use the WRT54g as a managed switch instead of the unmanaged netgear, but how is the question.
Any suggestions would be appreciated.
Thanks!
Thanks!
The only way that the setup you show will work is if you are supplied with multiple IP addresses from your ISP.
