headlight mod help, please
03TB93
hey guys, so im thinkin about tomorrow doing my headlight corner reflectors (nite-shading them).
My question is how do it get the headlight apart? i saw the tread for painting the headlight howsing but i just wanted to hopefully get some backup info or suggestions.
Do the 3 or 4 plastic clips on top just pry up? or do i have to somehow get the glue apart that somehow holds the headlight cover(clear plastic) or will the clips just let that pop off? thanks guy, help/info/suggestions, anything is much appreciated :thumbsup:
Oh and 1 other peice of info.. im not taking the reflector out, im just gonna tape off around it and paint it.
Thanks again!!
-Dan
:confused: If you're going to open your headlights, the inside gray plastic piece pops off, then the reflector will come out by unscrewing a couple of philips head screws.
Those clips you see were just for holding the assembly together while the factory adhesive set and dried. You're gonna have to either break out your Dremel and do some cutting, or try the easy bake oven method. Good luck man.
i have to open the headlight to get to the reflector though right? baisically i need to know how to get to the reflector.
Sorry man im sure im confusing the hell outta you lol.
It's all good man, that's what we're here for. I am assuming you saw my article that's doing this mod right? You have to cut the lip around the outside of the light, and inside where the crossbar goes to get the clear piece off. Then you can pop the gray piece out (good opportunity to color match it, or paint it black here) the reflector will be below that, held into the base of the headlight with some screws. You should be good to go from there. :thumbsup:
ya!! it must have been your thread i was reading about it. Did u just gut the peices aprt the a razor in between the 2 plastics? and did you just glue it back together?
You'll need a rotary tool, or a power drill with a cutoff wheel to cut through the plastic, then something thin/sharp to get through any adhesive the power tool didn't cut and to clean the joining parts so you can get a good seal when you're done. Pry the pieces apart, do your work, then use some RTV silicone to glue them back together.
cool man. I didnt know it involved all that, so thanks a bunch for the info. im prob gonna try it tomorrow and ill for sure let you know how it goes. thanks alot for the help.
hope it goes good! dremel works great (as stated by Blckshdw) haha I've cut mine open about 5 times now lol
p.s.
when you seal them back up try to avoid extreme temp changes from the temp they are sealed in to when you put them back on or you might get condensation inside the lens (I ran into this issue when I did it a few times) It was fixed with a hair dryer and a few days of getting acclimated to the temperature changes and your good to go!) :wootwoot:
cool man thanks alot for that bit of info, thats why i wanted to start a specific thread for this just to be sure. im probly gonna do this mod tonight, thanks fellas :thumbsup:
alright guys so im out there doing this now.. i cant figure out for the life of me wtf to do lol so do you cut the black plastic border with the clips off?? (the border i am talking about is like half an inch wide) or can i heat the glue up and try to get it apart that way??
right, i got that. i looked carefully. so do i use the dremel and cut the black plastic around the outside of the lens?
:yes:
allrrrightttttt. lol now let me go see if i can make this happen. thanks alot for the help man, ill be back on in like 30 to let u know haw bad i f*ck it up :raspberry:
alright guys so ive got the glue completly sperated from the light.. now its the middle peice for the crome bar to attach to thats holding me up..
Edit: did you just cut the shit outta that plastic around the center?
All you have to do is make a cut in the clear plastic, around that rim, that's inside the area that's covered by the crossbar. Once you do that, it should lift right off, then you can pop out the gray insert piece, and be home free.
Edit: In this pic, you can kinda see the route I took cutting the inside part
alright man, thanks again for all the help. :cool:
Ill post a pic when its done
:biggrin: I accept, cash, paypal, and cool things with LEDs in em, btw :wink:
LIke these?
[video=youtube;E1uxzy0WIwA]http://www.youtube.com/watch?v=E1uxzy0WIwA[/video]
[video=youtube;Pks9k1DZTM0]http://www.youtube.com/watch?v=Pks9k1DZTM0[/video]
[video=youtube;HKEBlnVVw1k]http://www.youtube.com/watch?v=HKEBlnVVw1k[/video]
:biggrin:
[video=youtube;TjNZKNe2cvE]http://www.youtube.com/watch?v=TjNZKNe2cvE[/video]
ItsOnVoy said:
LIke these?
If I was still a big gamer, I would be all over the PS3 controller. :thumbsup:
But right now, I use it mainly to stream Netflix :bonk:
Yeah the ps3 controller did look bad ass!! Hey stream netflix in style :cool::biggrin:
And 8 hours later here they are. now that its all said and done it was deff worth it. if you asked me that 5 hours ago, i would told you the compete oposite.
Thanks for the help tho guys. blckshdw, your the man!! :thumbsup:
Glad you got it all finished up. Job well done! :wootwoot:
Thnaks a bunch :hail:
fletch09 said:
looks good :thumbsup:
IMHO, i would have color matched (whistler mod), while they were apart.
thanks man. and i was seriously considering it :undecided: i still might do that,, its just held together with some glue and JB weld. i was seeing how the 2 tone would look. ill let u know if i change it :thumbsup:
mikeinDE said:
They look sharp Dan!!
Thanks buddy, i have an idea in mind for your truck when i was doing it. ill explain to you on sunday :thumbsup:
sweet, can't wait to hear it!!
devenmcc
