- Apr 9, 2012
- 934
It's been about a year now since I last posted when we still had our 02 Envoy. Recently my parents bought an 04 Trailblazer Ext for my brother to drive to school and its having some minor issue we can't seem to figure out. Currently its sitting at 143k miles and has the I6.
Here's what we've done to it so far;
Replaced the Autolite plugs with Iridiums
Replaced the Variable Valve Timing Solenoid (threw a code)
Cleaned the throttle body
Oil change
What needs to be done;
Front + Rear Sway bar links
Front + Rear diff fluid
Transfer Case fluid
Fuel Filter
Here's what we're trying to figure out, its mostly starting up the truck it feels a bit rough, kind of like it isn't getting what it needs to start,its worse when its cold, its hard to explain unless you feel/hear it. Next is the shut down, it feels very abrupt, the best way to describe it is like once you turn the key to the off position it kind of sputters and vibrates the truck enough that you feel it through the steering wheel and seat. The idle is very smooth so I'm just wondering if a bad fuel filter is to blame or if this is something else entirely.
Oil change
Transfer Case fluid
Fuel Filter
