Just about done most of the usual maintenance done on the 06 TB. Pulled off the front calipers, greased the pins with some silicon grease, pulled the passenger side CV and checked the disconnect bearings. At 220,000km the front pads and rotors are doing great. They were great so I threw in a bit more grease. Greased the tie rod ends, found out the "glug glug glug" sound it was making. I had ripped out the AIR pump but left one line hooked up to the solenoid near the manifold. Found the solenoid leaking a bit so it was building up moisture in the tube and finally it filled up enough to offer resistance. Got to block that off now too. Found the cause of the hard to fuel issue, pulled the vent solenoid and found it full of dirt and dust. A few taps later and you can now fill an empty tank without any issues.
Besides the thermostat and spare tire hoist, I need to do the TC fluid, grease the driveshaft U joints. Will see if I can get a few more years out of this old girl. Last year I hand calculated its mileage and it was sitting around 12.6 L/100km, which is down from the 12.1 or so 6 years ago.
