guiltyimnot
- Joined
- Mar 25, 2012
- Posts
- 20
I am looking to install a Blue Sea Systems fuse block to hard wire some things and add some things. Right now all I have done is used an add-a-fuse in the rain sense spot to add a 12 volt outlet in the 3rd row for charging ipods and such. I plan on adding another to the other side and eventually a CB and flashlight charger. I just wanted to run my schematic by all you knowledgable folks to see if I am on the right track. The blue line running from the rear fuse box to the relay is to ignition switch the blue sea fuse block. I saw another installation that used the circuit breaker but it was going straight to the battery so I am not sure if I need it or not. I apologize if my ms paint skills leave any questions and appreciate any help I can get. Just want to make sure I do this right the first time. Thanks all. View attachment 22226
