Midnyteryder196 said:
Yeah it runs pretty decent.. It just been having a p0171 code for a while now.. And now more frequently it hasn't been wanting to start up when warm
I rented a fuel pressure tester from oreillys.. And it said 32psi idling. Now wether the gauge was off or it really is 32psi I'm not for sure.. First time I've messed with a fuel pressure tester..
Fuel pressure is tested with key on, engine off.
Important: Verify that adequate fuel is in the fuel tank before proceeding with this diagnostic.
Turn OFF the ignition.
Turn OFF all accessories.
Install a fuel pressure gage. Refer to Fuel Pressure Gage Installation and Removal .
Turn ON the ignition, with the engine OFF.
Important:
• The fuel pump relay may need to be commanded ON a few times in order to obtain the highest possible fuel pressure.
• DO NOT start the engine.
Command the fuel pump relay ON with a scan tool.
Observe the fuel pressure gage with the fuel pump commanded ON.
Is the fuel pressure within the specified range?
345-395 kPa (50-57 psi)
