- Jan 31, 2014
- 105
Hello everyone,
I have read many posts on here and the OS concerning the front drivers differential seal and bearing (adjuster). But I have yet to find anything posted asking the how and why (if you will) of putting the seal and adjuster back in the differential. I'll explain in a minute.
To start, I have a 2004 TB EXT LT 4x4 4.2L. I was doing a fluid change on pretty much everything. When I drained the front diff., there was only a drip or two that came out. I was surprised and hoped that I did not have a leak because there was no evidence of a leak anywhere around it. No fresh or old oil splatters. So I filled it up with Amsoil 75w 90. I then drained and replaced the fluid in the rear diff. All's well there. So coming back to the front, I saw a pretty dramatic leak on the front diff. I'd say a good 1/8 cup in about four hours.
So. I tore the whole front left apart. When I got the axle off, the seal and the adjuster behind it stayed on the shaft. Went to the dealership (I learned on here these are dealer parts only) to get the seal and adjuster. Bought the seal there. They did not have the adjuster in stock. I got the part no. and ordered it online. I also ordered a new half-shaft.
Part numbers were:
Seal: 1925-7296
Adjuster: 2605-4695
I compared the new seal and adjuster to my old ones. They are identical in size and shape as far as i can tell. Now here's my problem, since the old seal and adjuster came out and stayed on the shaft, I don't exactly know how to put it back in correctly.
There are threads on the outer rim of the adjuster and there are threads on the inner diff. housing, so one would think that the adjuster screws into the housing. But this is not the case. There is a couple mm's of play between the adjuster and the housing. I then put the old adjuster in to see if it screwed in. Nope. Although, the threads on it were very worn down. It also had play between the housing.
Also, on the old seal all the tabs were bent in and flat against the seal. Ok I thought. The tabs on the new seal will fit into the tabs on the adjuster. This isn't the case either. There are 14 tabs on the seal and 12 indentations on the adjuster. No matter how you spin the seal on the adjuster, no tabs ever match up and (seat) into the adjuster. WTF.
So here are my questions.
Does the adjuster just [float] behind the seal and the inner bearing? If so, what the hell are the threads for?
If none of the tabs on the seal match the indentations on the adjuster, do they just get smashed down flat and look like the old seal? If so, what the hell are the tabs and indentations for?
I don't want to put it back together and hope for the best. I want to know that I'm doing it right.
Any thoughts?
Part numbers were:
Seal: 1925-7296
Adjuster: 2605-4695
Any thoughts?
