- May 31, 2015
- 4
Hey all,
I have a 2006 Envoy at 130k, with the 2HI,AUTO,4HI,4LO transfer case. 99% of the time it stays in 2HI as recommended.
Anyways, after a 900 mile road trip in two days I noticed a hum coming from the front end on a smooth road. Louder on a right turn, quieter on a left turn made me think driver side wheel bearing - no problemo. Ordered the timken and went to install it today, but now it's something worse.
The hubs are solid, no play or grinding. The noise is coming from the front differential case. It's a low clicking noise, like straight cut gear teeth contacting each other with no oil. I drained it and it looked like it had enough, at least 0.5 liter by guess (manual calls for 0.8?). And it was smooth black, no grey milk color to it, no noticeable shavings or metal particles.
Filled with synthetic 75-90, still heard the noise turning by hand, but went for a drive around the block anyways - still there.
There is maybe 1mm of linear movement in the drive shafts, same on both sides, and there is no noise when turning the passenger side wheel. It turns a little easier, if that means anything. There is a some play in the CV joint on the driver side, and a little less on the passenger side, but still there.
Here is a video of it. The noise seems to follow the speed of the gear that you can see in the video, closest to the oil pan, and is turning the opposite direction that I am spinning the hub. Noise is the same when spinning reverse or forward.
It is quiet below 35, then above that on a smooth road it is certainly noticeable in the cabin.
Any ideas?
The video makes the noise seem louder than it really is, but you get the idea.
https://youtu.be/MjyUlT_7DMc
Also, I found this video of another person hunting the noise. Both inner CV joints (the two closest to engine, driver and passenger shafts) have a similar slop to them, but not quite this much:
https://youtu.be/pRMtuU36lsI
Any ideas?
