- Aug 24, 2014
- 189
Hey everyone. Well one thing after another.... Just when I thought the truck only needed an oil change this time, when I took a look around the frame I was shocked by how much the rust increased. I noticed through the frame side tie down holes that the inside of the frame is peeling (and I was able to remove chips through the holes after hitting them with a screwdriver but they were fairly thin and did not result in holes in the frame), very small 1mm holes are starting to form around the inside of the rails where the body mounts are up front and I noticed the metal forming the leading edge of the weld under where the passenger side door was basically just rust and I can stick a screwdriver in it around 1mm but it isn't all the way through (shined a light in it and nothing). Otherwise the rest of the frame is great and has minimal to no surface rust. The rear axle has quite a bit but still solid and won't need too much wirebrushing to clean up. The driveshafts have been crusty since I got the car 4.5 years ago and two dealers said they were fine. I wonder how serious that weld really is....
Now I just got 6 quarts of the Eastwood Rubberized Rust Encapsulator to use on both of my truck frames (in addition to the aerosols I have left) since I noticed it doing a fairly good job on my old truck except the underside of the frame where the vehicle lift scraped away some of the paint before it cured. I think the quarts are the way to go especially in hard to reach places. Would it work to just wirebrush what I can on the Trailblazer, coat it with two coats on the frame, rear axle/suspension, between the outer frame and doors, control arms and then shoot paint into the frame holes where I can to get the internal parts coated where I picked pieces out so it stops rusting, and force some in that weld so it doesn't get worse? This truck only has 58,500 on it and I would hate for rust to claim it before high miles or mechanical failure... Especially since my 98 Jimmy with 133K has less rust. Thanks
