EXT Caliper bracket number
FlyingFischer
Spokane, WA
Anyone know the front brake caliper bracket part numbers? I am ordering a new CV axle and while I'm ordering from rockauto I was just going to order the front brackets so I can use the bigger EXT brakes in the front.
ScarabEpic22
728
Finally gonna upgrade eh Craig? Id sell you my fronts in a bit (going with Baer 6 pistons, lol) but I think Ill reuse them on my 02 instead.
Cant help ya on the part #s unfortunately, use RockAuto and find the caliper brackets for an 04 EXT?
FlyingFischer
Spokane, WA
Ah yeah never thought about that. HAHA :crazy:
But yeah I am going to go with R1 premiums.
Opeth
177
Anyone have luck with the part numbers? Rock auto only shows one part number but doesn't say it's for a SWB OR LWB truck. I also tried napa and they couldn't help either, their parts catalog doesn't show a difference in the brackets or loaded calipers.
Menthol
177
Maybe in 2006 they stopped making the EXT. This info if for MY 2003 EXT
Cardone FL 129" base 141159
Cardone FR 129" base 141161
I do not know if this will fit your's I think the rotors are also different. You can check 2005 and see if 129" wheel base is shown.
Goodluck.
oh05ext
166
autozone has the part numbers online,ss calipers and pads are decently priced,i thought about putting them on our ext.
RedVirus
40
this should help you find the ext caliper bracket number the link came from a member here on the forums
ACDelco Parts
Opeth
177
02-05 have two part numbers for L &R which says for the 129" wheel base, then the 113" have 2 other part numbers.
Then 06-09 have one part number for the V8 that's for left and right, which is different than the SWB part number.
14-1143 (5.3L and 6.0L)L&R
14-1144 (4.2L ) L&R
4,673
I'm fairly certain the 6.0 uses a different caliper bracket than the LWB models, the mounting points are the same as the LWB but the opening is slightly different to accommodate the larger iron caliper. I remember looking at this at AutoZone and the SS caliper wouldn't fit inside the bracket I had.
Sheik480
