Envoy XL Cargo Tray
The North Face Edition EXT had threaded plates set onto the bottom of that for the owner to screw in legs, to use it outside the truck as a picnic or food prep table, etc. You might consider adding that feature.
RayVoy
939
tokahao said:
Mostly because I finally found out what those notches in the cargo bay are for.
Haha, ok, now that you have the cargo bay notches filled, do you know what the hooks, on the tray, are for?
tokahao
79
Wish I knew... but whatever it's for, I want it! :undecided:
10,724
I like using it for groceries. Put the tray in the vertical position with the hooks facing the lift gate, then you can put the loops on plastic bags over the hooks, and your stuff won't slide around or fall over. :thumbsup:
TexazReece
damnit why couldn't they have it for us swb's :frown::sadcry:. Got any pics of how this looks in your TB EXT?
10,724
Not ATM, I leave the tray on the bottom mounts, and my sub box sits on top of it. I'll move some stuff and snap a couple pics tomorrow, unless someone else posts it first.
10,724
Tray on the bottom, where I usually have it... Carpet side up, hooks down
Upright position, hooks out, sits flat against the back of the 3rd row seats when they are in the seating position.
Upper mounting position, hooks and tray up, carpet side down. If my sub box was shorter and wider, I would leave it up here.
Bbcman601
