xxxotiknightz said:
Well, im taking the Denali home to Tennessee to my old mechanic. He's putting a new engine in w/ 5yr- 100k mile warranty. $5000 bought and installed.
Well, I just got my truck back and believe me, it runs better than ever. However, I wanted to share a few things that may be noteworthy...
- Depending on how much the engine is, and the labor cost, I think $5K is going to be a very conservative estimate, and I bet that they will lit you up for more labor. My cost was around $6K once I included the cost of seals, gaskets, water pump, belts, plugs, wires, exhaust manifold bolts, and pretty much any thing that is considered a wear item. The extra parts alone cost me around $800 on top of the cost of the engine. I know you may want to reuse parts, but this is a time where I personally think going the less expensive route is being penny-wise and pound foolish.
- Soak everything with PB Blaster... multiple times.
- This engine is a bear to get out because of clearance issues. In fact, I have been told that some Chevy dealers actually remove the body from the frame to make this easier. Saves a lot of labor - they claim they can do that part in about 45 mins.
- To make the new engine go in a lot easier, four bolts holding on the engine mount brackets were trimmed. They hung the engine up going out.
- Burping the air out of the cooling system is nothing short of a pain in the rump. Try to bleed air out when filling by removing one of the coolant crossover lines above the water pump. It took nearly 2 hrs to get all the air out of the system and nearly overheated the new engine a few times. Ill repeat: WHAT A PAIN!!
- Make sure you follow the break-in procedure for the new engine and then dump the oil after about 1000 miles. Keep track of all work done so that you have records for the warranty.
I hope this helps... let me know if you have any questions about my recent experience... I got to see most of it done and assisted in a bit of it.
