3 or 4 times in the last year my truck has dies when idling at a light or in traffic. Seems that it only happens when the weather is warm & the AC is on. AFAIK the engine is always warmed up. I am wondering if it's related to the throttle advance when the AC comes on. Always starts right up & then runs fine & doesn't throw a code. Throttle body was cleaned recently & plugs are new. Am now running some injector cleaner through the system. The injector cleaner is just a what-the-heck-can't-hurt attempt, 'cause I would expect a code if it's related to fuel or ignition. Any insight is appreciated.
Thanks,
kev
Thanks,
kev
& idle has been fine. That was the same 3 months ago too. I'll check the hoses, but it runs/idles great. Just those 2 times in 2 weeks most recently. Last time was last spring when the weather warmed up & was using AC. It gets hot here all summer, so I run the AC most of the year without issue. I had the battery disconnected again 2 weeks ago to do some stereo work, but unsure of the timing of the incident.
