If you're desperate, boneyard might help. Just make sure you get right harness. Later trucks have two hots, one for module and one for wiper motor. Early trucks had only one hot in the connection above the headliner. You can pull on the harness at the body right after the flex connection and the connector will come out. You can use a meter to determine if you have voltage at the connector.
If you have power at the connector but not at the lift gate control module it is broken wire. Does your rear wiper work? What year is your truck?
