- Jan 24, 2012
- 14
When I open and close the driver's side door I hear clicks. It happens when the door is almost fully open. It does not come from the hinges, rather the curved black arm that slides into the door through a rubber boot. (I took the arm loose [two 10mm bolts] from the frame and the clicking went away.) This little arm goes into the door when you close the door, and I don't see a way to shoot some lube onto that arm to stop the clicking. It's not at the end that I can see, which is a pivot point. Any ideas?
