Dome Light Tap??
STLtrailbSS
I put some 24 SMD leds in my foot-well in place of my old blues and I had originally ran them to a switch but now I just wanted to add them to the Dome light circuit anyone know A + Wire I can tap to get these to work on the same circuit as the domes? Or does anyone have a diagram but All I really need to know is the color and what harness its running from, nothing too in depth. Hopefully someone has already tackled this one
It's a gray wire with black stripe, and I haven't tapped into it myself, but the shop manual implies it goes up to the headliner area by way of the driver's side B pillar. IIRC, a post on the OS said he had found it running up the A pillar instead. It comes from the rear fuse block in any event, so the B pillar makes a bit more sense.
Roadie Saves The Day Again, Well once the sun gets up and this 28 Degree weather decides to warm up a bit I will get on it.
Which wire in the overhead console is a constant +12v (to power the tap on dome light) and which one is ground? I plan to put a switch up there and I want to use those wires to power the switch which will go to a relay.
I can check the schematics after work, but if you're pulling the console off tonight, just check with your meter. Ground is almost always black, and the lamp hot wire should be obvious by its connection to the lamp socket.
Which console do you have? What features are in it, in other words?
Here is a picture of my console with the switches installed. They are not yet wired up...
After looking at the 07 wiring diagram, I see a gray/black wire, an orange wire, and the black ground wire. IIRC, the gray/black wire is the courtesy lights, which means the orange wire is for the reading lights. When I trace the orange wire in the diagram, it says "lamp supply." The gray/black wire is "lamp control."
Is the orange wire the correct one to tap into to power these switches?
Yes, the orange wire is the one you want to tap for your switches.
Does the orange wire turn on and off with accessory, or is it always on?
It's always hot. I added the Homelink and Memo modules to my overhead console, the orange wire is used to power them both. Also, this is how your dome lights come on when the door is opened, but the key is off :twocents:
abdo
