Differential oil 75w/90 recommendations please
c good
647
I'm currently running Mobil One Full Synthetic in the front and rear differentials. Any other brands I should consider? I've run Valvoline in other vehicles over the years with good luck. Am I missing anything? Thanks for any suggestions.
8,272
If your Trailblazer sports an Eaton G80 "M-Locker" Rear Differential...You'd better drop in on THIS Thread and confirm that NO LUBRICANTS WITH LIMITED SLIP DIFF ADDITIVES SHOULD BE USED:
...and THIS Article, too:
THIS is the "No LS Additives" Flavor for the Eaton G80 Rear Diff Gear Boxes:
8,272
What does the RPO Glove Box Sticker show ...instead?
c good
647
Any suggestions on the brands of 75w/90? Mobil 1, Valvoline, Amsoil, etc?
Really any good brand synth 75w90 is fine. Heard that Amzoil is the best but I never go into those boutique oils which are excessively priced.
8,272
Whatever you DO wind up "Putting inside of The Pumpkins" ...is going to be much better at BOTH ends of the SUV than whatever is inside of them ...Right Now... :>)
rezha
