Cross bar question
mmassow
3
I broke the cross bar on my roof rack on my 2005 EXT trailblazer. Are the EXT cross bars the same as the ones on the swb? Pull-a- part has a swb model. I don't want to go there if they will not work. Are there any aftermarket cross bars that will fit the track on the factory side rails? Thanks.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Yes, they are the same. Aftermarkets are from the normal sources.
mmassow
3
I was wondering if they were the same because I see two different GM part numbers for ext and swb. I really want to stay with stock because they are cheaper.
mmassow
3
I went to Pull-a-Part today and got one off of a swb. It turns out it is about 2 inches longer than the ext, but I just needed the mount that goes in the rail, so it will serve me fine. My original one is bent where the cross bar slides in to it.
RickRamz
