codes on abs
popeye
got a 2006 trailblazer 4 wheel drive abs kicks on when slowing down and the traction control kicks on in the morning at first scanned codes c 0196 c0287 c0131 c0040 c0045 c0035 c0050 c0245 c0244 and no abs light
I just went through this crap with my truck. I didn't have as many codes but under the driver side door there is a 8 ga or so black ground wire. Remove the ground wire and use a grinder and make sure you have a metal to metal contact. Mine was pretty corroded and doubtful it was making a good ground, then clear your codes or leave your battery un hooked for 30 mins. Some of those might be old stored codes, but if your abs is pulsating it is probably due to a dirty wheel speed sensor.
This post is a little old and I am not sure if you have fixed the problem yet but I did have the same issue. With that many codes it is most likely electrical. The one issue to look at is your EBCM. It is located right next to the grind wire you cleaned earlier. Due to it being under the car it is subject to a lot of vibration as well as road grime. A lot of times these abs codes are kicked because the EBCM has a short in it. There is a guy on eBay who will fix this, he's legit. Just search "Trailblazer EBCM" and it should come up.
My specific problem was fixed when I was getting ready to pull the EBCM out and noticed the wire you see below had a lot of corrosion and was shorting out the abs system. All I had to do was splice in a new wire.
Sexyscissors
