envisionelec
- Joined
- Jun 20, 2012
- Posts
- 27
2002 Bravada, 218k happy, well cared-for miles. Stock everything except the radio which I recently replaced (but the problem was happening prior to that).
The cluster will "reset" itself several times in a row. I've paid close attention to the sequence of events.
1. Start the truck. All lamps light and extinguish (normal).
2. Within 5-10 seconds, some or all of the lamps will re-illuminate and go out.
3. The DIC will "blank out" and reappear - the sweeping (curtain call) VFD characters will reveal "Driver 1" or "Unknown Driver"
4. Sometimes all of the steppers will drop to zero and reset - as if I'd just restarted the vehicle.
Today, I got something different:
1. Idling for 10 minutes at a drive through
2. Battery gauge dipped to 9V (but no other dimming in the vehicle)
3. Lights did their on/off dance.
4. No other gauges dropped
5. Repeated 5-6 times
A few months ago, this occurred and the engine died. I was able to restart it immediately. I replaced the ignition switch the same day.
Conditions:
High humidity - cold or hot. Heat + humidity seems to cause more occurrences
Mostly at or near start-up
Rarely while driving (but I don't stare at my cluster)
Will go weeks without doing it
Has been happening daily as the weather warms up
I tried to get some video of it - but it became camera-shy.
What's feeding the cluster's battery gauge? Is it straight from the BCM? Is it data? I want to try to repair it myself. I have 20 years as a EE and lots of bench test gear. Some pointers in the right direction would be invaluable.
Thank you so much!
Conditions:
Thank you so much!
The voltmeter is fed by the PCM (engine mounted module) data stream along with the other gauges. The PCM contains many A/D converters, as you can guess. The BCM has others, but in this case it's the PCM. Anyway, if your lights aren't dimming, then the voltage excursion is localized to the PCM, and that's either a flaky ignition switch, high resistance intermittent PCM fuse (there are 3-4 of them IIRC), or a flaky ground. I'd remove and reseat the three connectors to the PCM, reinsert all the fuses, and check the ground wire going to the fender. The instrument panel sometimes also goes nuts due to a loose bolt or oxidation on the master dash area ground star point, at the bottom of the center radio/HVAC stack on the passenger side.
It began working perfectly after it cooled off outside and the humidity dropped.
