I've got a 4.2 I 6 03 tb. I just replaced the engine about 2k ago. I've had a few problems that got fixed(loose grounds). A few days ago, I got to work, sat for about ten mins, and the battery was dead. Didn't have anything running. Figured the batt was just bad so I went and got another. Came out this morning and dead too. Jumped it. Ran long enough to get it charged, stated charged for a while, but I could hear something running. Figured out it was the throttle body. Its making some kind of whining noise.After a few seconds(15-30) it will make a different noise, and one of the relays will click, then goes back to it. It kinda feels like a fuel pump relay, but may be the vibrations going through the fuse box. It only stops if I unhook the battery, or the PCM fuse.I didn't see any broken or frayed wiring but I haven't been able to follow it all the way. Also the check engine light will stay on after I turn the key off And remove it.occasionally the security light will come on also.
I took it to O'Reillys earlier and they tested the alternator, told me voltage regulator was bad. I had a spare alt that came with the new motor, so I slapped that on there. Charges fine(seems to anyways), but the noise is still present. I also had a spare throttle body( also on the replacement motor) so I hooked that up(just the plug not actually mounting it) and still It goes on. Didn't change the deal with the security or cel though. I'm wondering if maybe the bad voltage regulator may have spiked and shorted out the PCM? No driveability problems when it starts though so idk. Any suggestions?
Edit: also seems that the fan clutch stopped releasing. Friggin loud as hell if it can be heard over my side dumped straight pipe. Can I unhook the plug and it stay released or is it normally closed? I'm running with no hood and temp doesn't get above the first big line unless I'm idling and even then its only about halfway to 210 from the first line(160?) So the fan isn't a big problem if its not running. Killed my mileage though(used a quarter tank in about 30 miles)
