First, I would like to thank everyone that created this site and the "other" one. Guys like me would be lost without you. I have learned a lot about my Trailblazer from reading here and the "other" site. I do apologize if I have posted this in the wrong place. I did a search and could not find an actual topic concerning my questions. I have a 2002 Trailblazer LT EXT 4x4. I need to replace the actuator located in the center console. I read somewhere else that if that actuator is damaged or fails it will cause the other (I am assuming rear) actuators to reset to default and stay there. Is this true? Once I switch the heat/ac controls to the rear panel nothing works for the rear. No roof to floor control, no heat/ac control, and no fan speed control. While in front control mode, I can only control the fan speed from the front center console switch, but nothing else. So far I have had to manually remove the rear panel and "lock" the actuator doors in place to switch between heat and/or ac and for roof to floor. The actuators look to be in perfect condition as well. Could the center console actuator be causing this problem alone or should I go ahead and plan for new rear control unit (3 knob - manual controls) as well?
