Nizar said:hello
any idea about what can i use to delete the Catalytic Converter or what to use for the o2 sensore after the cat ??
ConeKilrAutoX said:hi. what would you like to delete the cat for performance and or loudness?
....well there a lot of options I considered when I deleted my cat. you can gut the cat and keep it there (could rattle) you could gut the cat and run a piece of pipe through it (still could rattle ). or run straight pipe. the only reason I deleted the cat was because of my turbo, the stock cats are pretty high flow unless its clogged and you dont pick up too much performance deleting it with the na setup. so i ended up with just straight pipe no cat =[ and deleted the 2nd o2 sensor and had lime-swap.com tune my pcm and also delete the error codes for the 2nd o2 sensor. luckily i have an emissions exemption now...
DJones said:Not to mention a $10,000 fine if you get caught.
blazinlow89 said:Not sure if that is a federal fine or state. I'm just glad that our county is exempt from emissions testing.
- - - Updated - - -
Wooluf1952 said:I'm thinking our state and federal laws may not be enforceable in jordan amman.
